15A Brake Fuse Blowing
I have added some LED Passing lights to my 2009 FLHP a month or so ago and I have blown two fuses so far. It seems to be random and nothing out of the ordinary from using all other lights to make it blown. Can I use a 25A fuse or will that burn up some other stuff? Any other suggestions. I cna't see how the LED lights are more amps than the standard lights before.
DO NOT increase your fuse size. Ya got something wrong or one of your connections is shorting-out somewhere. A 15 amp circuit should be able to drive a million candle-power Q-Beam so (you're right) feeding some LEDs should be a piece of cake.
The other thing to check is your rear brake light switch assembly. (Down low on your frame, behind foot rest on right side). If you're hitting this switch with a pressure washer, water can get in there.
You are shorting something out somewhere. Best of luck.
I had the same problem after installing a tach on my RK (nacelle mounted tach, not the speedo combo). The brake light, turn signals, and horn all run off that same fuse. In my case, I found the wire behind the horn had chaffed and was touching the front of the rear cylinder, but that wasn't yet shorting so I had to keep looking. As it turned out, inside the headlight housing the main wiring harness was being dragged across the grease zerk for the head bearing, and eventually wore through and shorted that circuit to ground. If you don't already have one, get a factory service manual for your bike. The wiring diagrams will be a great help. Given that you just installed the passing lights, I'd be looking inside the headlight housing.
if you have a lowering kit installed, odds are you have a short due to wheel rub on the wiring harness which runs under fender. had that problem and wound up running the harness in between fender and rear tunk.
if you do not have a lowering kit....check your install...some LED packages include a load resistor which the only purpose is to provide a load so that you blinkers work correctly. If you have a load resistor, under peak over voltage situations, the current could exceed design and blow the fuse. Current is liniear to voltage applied. If this were the case, you would need to check your system voltage, and if it checked out OK, you would need to contact the vendor of the LED system and discuss options for using a voltage divider instead of just a droping resistor.
I would start by taking a look at the wiring diagram and make sure that the passing lamps are on the same circuit as the brake light fuse. Not sure if they are or not. Have you changed any thing related to the brake lights? I have seen a wire get pinched under the tail light lens on a RK
I like to revisit this topic on my lights. I still have my 15A Brake fuse blowing. I just don't turn on the pursuit or some say passing lights on anymore. I have my bike broke down a bit and disconnected almost every source to the brake fuse that I can. My brake light assembly is disconnected in the back and passing lights disconnected at the front. I do believe this is a ground. Heres why:
I put a 20A fuse in just to see if it would hold the power. It blew right off the bat when passing lights engaged. So to me this would indicate maybe a ground and not too much current since all my lights are disconnected.
Here is my dilema: I am trying to follow the wiring diagram for my FLHP and the ground wire is only going two places. One is the brake relay. And the other the pursuit light harness.
I attached the diagrams which show the 15A trace along with the pursuit ground.
Can someone please help me or guide me to some sense of this? If anything a way to test the ground wire.....Or am i looking in the wrong place. Could it be anywhere else but these places. Thanks
