Support bracket necessary for front docking kit?
I'm about to install the front docking kit for a backrest on my 2008 FLHTC, the docking kit is part number 53803-06. The instructions say that part 53805-99, a support bracket connecting the front and rear mounting points needs to be installed but it doesn't come with the docking kit, it actually comes with the backrest. I bought my backrest used so I don't have them. Are they really necessary? In the instructions for the docking kit the support bars are item K in the diagrams.
My '07 should be the same as your '08. It's been a few years but here's what I remember about installing my quick disconnect sissy bar. My bike had the docking "spools" already installed when I bought the bike new. I bought the sissybar upright and Quick disconnect side plates from Zannotis over the net. Of course the little brackets or "tie bars" weren't on the bike. I tried to just snap the side plates on and found that the spools were about 1/4 inch off from the holes in the side plates. When I loosened up everything and installed the little brackets everything lined up fine.
So those things will get the spools the proper distance apart to easily use the quick disconnet side plates.
Good Luck and keep ell your bolts loose till you get the proper spacing. Also very impotant use locktight and lock washers on all bolts,,,, You sure would hate to loose one one the road...Don't ask me how i know....
I'm talking about the spacing between the two spools on each side, not spacing the spools out from the center of the bike. You'll see that if you just bolt on the spools the distance between them is probably different than the spacing of the slots in the side plates. You'll have to loosen the saddlebag mounting brackets a little to install the spools with those brackets. The brackets tying the two spools together provide the proper spacing for the side plates to snap on and off. Tighten everthing up once the correct spacing between the spools is achieved. Once the spacing between the spools is right you can see if washers are needed to space the spools outboard to align with the sideplates together with the upright installed.
oldbie
08-05-2017 10:06 AM
