Learned how to start my bike w/o Key fob
Rode my bike to work today. Left an hour early to enjoy the ride home. Helmet on, gloves on... when I realize the security system was not disengaging. After cycling the ignition and walking away from the bike to reset the alarm I finally got the alarm to reset and was able to fire the bike.
When I got home I read the manual on how to bypass the security with the pin. I also went for new batteries for the key fob.
Received 2,523 Likes
I posted this earlier this year:
Thanks to reading HDF, I knew I might need to manually disarm my security system some day. So before I picked up my 2003 FHTCUI, I had Racine HD reset my personal code to something I would remember. I never checked to see if it really worked, but tonight there was thread about a guy who lost his fob and didn't know code, so now he has to buy a new module. So I went out and manually disarmed my alarm. The code worked, the 2nd time, first time I didn't read the directions right. So I am posting the directions in a condensed version that you can access if you don't have a manual
1. Kill switch OFF.
2. Ignition switch ACCESSORY
3. Hold both directionals in. Security indicator lamp will flash rapidly. (The one on the speedometer).
4. Enter numbers of personal code by pressing left directional the number of times in each digit followed by pressing right directional. For example:
If code was 12345 you would press left directional 1 time, then right directional. Then LD 2 then RD1, LD3 RD1, LD4 RD1, LD5 RD1..Sounds complicated but when you do it it is actually easy.
5. Security lamp will stop blinking, you are good to go. I recommend doing this at home on a nice day, not on the road in a thunderstorm, while your buddies are calling you an idiot.
If you don't know your code I think any dealer can program it for you. I also carry extra fob batteries, with me. It is a 2032 battery available all over, actually cheaper at HD dealer than most stores.
1. Kill switch OFF.
1. Kill switch OFF.
1. Kill switch OFF.
Ride safe!
i feel like a broken record telling people to learn how to use their code. you never know when you'll need it. it may not be just the battery in the fob going dead. it could be a lost/destroyed fob, or even if you park in an area where there is some kind of interference. its a whole lot easier to punch in a few numbers than to push a heavy sumbitch around the parking lot trying to get away from the signal interference.
i make it a habit to go through the procedure once or twice a month, just to make sure that if/when i need it, i won't have any problems.
