Belt Dressing????
Old 07-24-2011, 11:06 PM
frontiercat's Avatar
frontiercat
frontiercat is offline
Fairing brackets cracked or broken?
Old 07-25-2011, 08:09 AM
cochon's Avatar
cochon
cochon is offline
Two things. If you still hear the squeak when it is in neutral, it is not the belt. Also, belt dressing will not fix the problem if it is your belt. Belt dressing will only cover up the symptom. If your belt is squeaking it is too loose, too tight, out of alignment, or your pulleys are worn.
Old 07-25-2011, 08:14 AM
av ultra's Avatar
av ultra
av ultra is offline
Hate to say this but every thread I've read about this ends up being a stuck valve guide.
Old 07-25-2011, 08:35 AM
mrfikser's Avatar
mrfikser
mrfikser is offline
check the wheel bearings...
Old 07-25-2011, 09:31 AM
rh8234's Avatar
rh8234
rh8234 is offline
The subject of chirping drive belts comes up every few months. I've posted this suggestion before.
Drive belts will make a chirping sound if they have a little brake dust or dirt on them. The best way I have found to clean them is to use warm soapy water and the wife's toothbrush. Chirp goes away, but the wife's teeth get a little black. Seems to be a good trade off.
Mr. Mike (06-28-2019)
Old 07-25-2011, 09:37 AM
Mikey V's Avatar
Mikey V
Mikey V is offline
DELETED-sorry, already mentioned(faring brackets)
Old 07-25-2011, 09:47 AM
dirtracin23's Avatar
dirtracin23
dirtracin23 is offline
If it makes the noise while not moving, it is not your belt.
But, here is quick, easy, and cheap method to silence a sqeaky belt. Rub a little soap on it. Ivory bar soap works the best.
Back to the OPs original problem. I'm suprised no one has chimed in with the obvious. You could...............
A) Buy louder pipes
B) Buy an amp and upgrade your speakers
C) Trade motorcycles
Problem solved.
JK
Old 07-25-2011, 09:51 AM
steelerdude1's Avatar
steelerdude1
steelerdude1 is offline
I will check them. I did have the left side break, and repaired it about a month ago. I wonder if one of the bolts on the L bracket came loose. Thanks, something new to check.
I know noises are tricky, but my chirp sounds like it is from the rear.
Old 06-24-2019, 11:48 AM
CUSTOMBYKER's Avatar
CUSTOMBYKER
CUSTOMBYKER is offline
Stage IV
Chirping noise also coming from right rear and I swear it's coming from my exhaust but have not inspected issue yet.
Old 06-24-2019, 11:55 AM
cprhed's Avatar
cprhed
cprhed is offline
Received 1,065 Likes on 614 Posts
You said you can get the squeek in neutral if you rev it up. Have someone else hold the throttle and get down on your hands and knees and crawl around it slowly to see if you can at least narrow down the area.
That being said, I haven't seen mention of this but the horn. That little thing is rubber mounted. Perhaps that it is.
But realistically the squeek happening even standing still when revved up means it isn't in the drive line. It is something squeeking due to resonate vibration. Look under your seat. Could be a plug that is rubbing somewhere.
I really like the baby powder idea for testing if it is the belt though. Way smarter than oil.
Quick Reply: Belt Dressing????
