A question about center stands.
I'm looking at installing either the HD center stand or the WheelDock EZ-Up on my '06 CVO Ultra. For those of you who have had either one or maybe both, what are your likes and dislikes? Is one better than the other? Are there any ground clearance issues? The previous owner lowered the bike one inch, and I had to raise the floorboards and remove the extensions to get some clearance back. I had the RivCo center stand on my '01 and loved it. The only thing I didn't like was having to be off the bike when putting it on the center stand.
Thanks
Thanks
I also love the EZ-Up from Wheeldock.
I've nicked the road when cornering but only if the road is uneven.
Sometimes I'll nick a speed bump with a passenger on board if I go too fast or forget to pump the shocks.
Never a hard hit at all. Never found it to be unstable.
Obviously it's only reasonable to use it on smooth flat surfaces.
I love the look on peoples' faces when they see a 900# Harley standing upright.
It's real easy to put the bike up on the stand from the seat.
View the video on their site then talk to Rod, the owner.
Very few people dislike them enough to remove them.
Like I said I had a RivCo on my '01. It was a good set up, but I want to be able to put it up while straddling the bike. I know you can do that with the Wheel Dock EZ Up, can you do it with the HD one?
And yes, the RivCo dragged in aggressive corners and it did hit on tall speed bumps and driveways, but I got used to that.
I do agree, the ground needs to be level and smooth.. If the ground slopes forward - it may roll off the stand and if the ground tilts left or right - will NOT work..
I learned very quick - make damn sure both feet (from the stand) are making contact with the ground BEFORE you put weight on the lever -
Other than that - stand works great and is very stable - use it all the time.
Lost it twice in the past several years - BOTH times it was My fault
