oil Temp
Oil cooler is on my list as of yesterdays ride. My bike gets hot and I have got rid of cat. etc. No I have not had a failure but I am surprised at how much heat I can feel on my legs. NOT all the time but I can really feel it on my legs when the bike gets hot and yes it is running better/cooler not in stock form. I hope a oil cooler will help a little bit.
this is one where everyone is right and everyone is wrong.......if you are in a metro area and have losts of stop and go traffic...then the other metro riders who are pro oil cooling have the correct answer for you....BUT...if you are a rural rider that can ride the open wind with little or no stops...THEN...the other rural riders that say don't worry about it, its all good, have the correct answer for you.
Synthetic oil gives you an added edge when running these latest model bikes that run so hot. I've gone to Redline 20W-60 and it seems to have quieted the motor a bit too. My '09 RK on a HOT day will hit 260*+ and in one instance it hit 280*. Usually it's at 240*-250* on most days, maybe 230* on a cool nite ride is the lowest temp you'll get.
No oil cooler yet, these are temps with a stock bike. I'm just now working on completing a Stage I and an Oil Cooler is next on the list. Wanna bring these temps down for longevity reasons.
I've been running amsoil since my 07 was new, it has 65k and runs 260-280 on a warm day and has hit 300 on a hot day running hard with no concerns, as mentioned the motors are built to withstand the high heat and a good synthetic can withstand the high temps, amsoil is rated for 400+ before the viscosity starts to break down. From what I've heard a cooler will cool the oil from 10-20 degrees and only if you are moving they are worthless in stop and go traffic. IMO a cooler is not necessary; it does give piece of mind to some.
