primary bearing - where's the race?
great picture....I was going to buy a used inner primary cover and have it sent out for a new bearing.....but that would still leave the issues of replacing the race on the shaft....seems like the tool is almost 300 bucks...hate to put a torch on the race to get it off and risk melting seals....Ive dremel cut races in the past successsfully, but I always had access to the whole length of the race....how are you folks removing this???
What year is your bike? How many miles? Assuming you have a newer one, I think the Baker and SS only fits the TC88's. The puller tool works well, but you can dremel it off. I started with the puller on mine, but the shop's tool was getting stripped so I ended taking a dremel to it and wrapped the shaft in several layers of masking tape and went slow. It came right off no problem. Pressing one on is easy.
imskier2 - What kind of "symptoms" did you notice that led you to suspect the inner primary bearing. I've got some new noises that I'm trying to track down and I'm beginning to suspect the inner primary bearing.
To the OP.....sorry for the thread hi-jack.
