2007 Road King rear cylinder quit firing
Old 08-05-2011, 08:08 AM
Sailrider 1's Avatar
Sailrider 1
Sailrider 1 is offline
Default 2007 Road King rear cylinder quit firing
I have a 2007 Road King Classic with a PCV. A few weeks ago my rear cylinder quit firing. Threw codes for rear cylinder no combustion and rear cylinder coil / open/ shorted. I checked the rear plug, it was cool definitely not firing. Swapped the plug with the front cylinder. No improvement. The rear plug did not have any fuel on it either. I replaced the coil, no improvement I disconnected the PCV and ran the bike without it, same problem. I reconnected the PCV, same problem. But low and behold a few minutes later I started the bike again and it ran perfectly. Went for a short ride about 20 miles, the bike ran perfectly.
I am now at a loss of what the real problem was and if it is actually fixed or not ? I take long rides in the middle of nowhere and now have no confidence that the bike is reliable. Could it have simply been a bad connection at the PCV ? Will that throw these type of codes ?
Also does a 2007 have limp mode or a rear cylinder shut down mode for heat ?
Old 08-05-2011, 08:30 AM
mrfikser's Avatar
mrfikser
mrfikser is offline
check the connections to the rear coil..esp the ground/neutral..
Old 08-05-2011, 08:36 AM
MrHog's Avatar
MrHog
MrHog is offline
I don't think they had "parade mode" on the 2007 touring bikes.
Old 08-05-2011, 10:28 AM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
in late 07 or early 08 a free one time parade download was available for the 07". yes it could be a bad conection,a few have had problems with the pins galling or water,clean it out add dielectric grease and plugg it back in,however there is alot of other posibilities. no fuel on a plugg thats not firing would have me starting with fuel related conectors like the ecm plugg and the injector plugg.
rsscoggins
12-14-2015 03:48 PM
monumaker
04-08-2012 09:32 AM
XtremeHD
10-12-2011 05:22 AM
normski
03-23-2010 10:03 AM
Bad Pig
07-09-2009 07:10 PM
Quick Reply: 2007 Road King rear cylinder quit firing
