NightRider XIED’s - FL-ViED-10 or FL-XiED-10 ?
A friend just put these on his 2012 Ultra (FL-ViED-10) and is really happy with them. He kind of got me a little excited and I was thinking about putting them on my 2011 RKC. Is it all hype or do they really help to enrich the AFR? Anybody using them, happy with them? Which model did you use, the FL-ViED-10 or FL-XiED-10 ?
Received 24,525 Likes
I have a set of XIED's on my '08 .... 40k miles with them.
I realize its not exactly what you're asking opinions on.
I have the HD breather along with Rush slip ons.....
Bike runs flawlessly, and I'm getting between
47 and 51 mpg....depending on riding style.
And yeah, my bike does run cooler after the installation.
I put a set of xied-10 on my Ultra about 6000 miles now with no problems i did this to cut down on the heat not for performance I gutted the cat and wrapped the pipes stock exhaust and a/c if I was looking for performance I would do some sort of stage 1 but it seemed to be the cheapest way to reduce the heat and it seems to do this well.
Someone should call Steve at Nightrider and ask but as I remember it the difference was Xied = 13.8 and Vied = 13.8 to 14.0. I was very happy with the Xied's but my bike turned out to be one of those that have a bad ground in the ECM and the Xied's stopped working, the moco would not replace the ECM so I have moved on to the TTS. Using the TTS I can tell you there is only a slight difference between 13.8 and 14.0, performance and gas wise it is hardly noticeable in most cases. If I had it to do over again, I would still goes with the Xied.
I looked around on the Nightrider web site for some instructions (pdf?) and did a Google search, but came up empty handed. Since I just gutted the cat from the head pipe, I know both cat leads plug in under the right side cover (as I sit) and are easy access. From what I can see, it looks like that's all you have to do, just plug them in, right? And the FL-ViED-10 is adjustable, so I guess you do that before buttoning it up. Am I on the right track here?
I still have the cat in the header 2011 FLHTK 2" baffles and SEAC, plug and plug right were you discribe, have mine set at 14-1 works for me, without the cat you can add more fuel with vied.
