Resetting the ECM?
HD stealership will tell you they have to "Flash" the computer to reset it, but thanks to a fellow HDF poster we have instructions on how to do it ourselves. I used these instructions last night to install a new TSM switching form a TSSM so I had to get the computer to forget the security system that was locked!
You will need a battery charger to do this as the process takes 30 min with the ignition on and the bike not running.
https://www.hdforums.com/forum/engine...ml#post7910911
Corkyspeoria (07-10-2016)
Guest
Posts: n/a
https://www.hdforums.com/forum/engin...ml#post7910911
This is the correct link for what DvlDogBkr was talking about
Flash the ECM
It will only dump the security if you've replaced your TSSM, it relearns all the electronics that are plugged in. If you take your SERT off and do this operation than yes it would forget it.
Thing is that, there are no tuner shops anywhere near here. There is a Harley dealer 20 min across the border in Caribou Maine, that's it. I wouldn't know the first thing about setting a fuel processor, so I figured I'd hop over to the HD shop in Caribou and get the download on the stock ECM.
I also heard about some units being pre-programmed for your particular application, but other than working around the battery area, I would be comfortable lifting the tank and such. Tried it once on my 05 Nomad, and ended up kinking the fuel line and shorting another wire.
Getting factory tune in the bike
Hey guys I have a 2007 street glide I think the download is bad and has to much enrichment in it at start up and only gets 30 mpg .I bought this bike used and want to put fuelmoto tuner on it ,how do I get the stock map in it so I can do that
the bike has stage 1 cams and se air cleaner and rush slipons
thanks
ROD
thanks
ROD
thanks
ROD
thanks
ROD
What tuner? If its a PV, FM can probably supply it as well. Maybe someone on the forum has one as well.
Sent from my Galaxy Nexus
I was told by the guy I bought the bike from that harley did stage 1 download. I call the dealer to find out what had been done to the bike , cams air cleaner exhaust and download. They blew me off so I really don't know what I have I do know it has no tuner installed on it.
That's why I wanted ECM set to stock and go from there
