Good Crash Bar Mounting Lights?
If you're willing to consider another mounting option than on your crash bar:
http://www.motolight.com/
A bit pricey but very effective at presenting a larger light image to traffic.
my thoughts- crash bar mounted lights will partially illuminate the front wheel at night- reflections from the wheel off to your sides are distracting- tried on a run through the desert on I 10. turned them off, then took them off.
so then i looked at the other units---- if the priority is being seen, these lights are mounted too low.
I don't have a positive suggestion at this point- in AZ it is legal to run high beam in the day so I do- I dip my light ( thus bringing in the passing lights) if i see someone who's eye i want to catch.
mike
mike
mike
mike
I ended up adding these to my bike. $139 delivered and because they have 4 Cree 1800 lumen leds each they are incredibly bright and really light up the road. They don't come with a wiring harness so you'll have to come up with that on your end. I have mine wired to my auxiliary light switch and mounted them to my upper brake caliper bolts using brackets I got at a home center for about $5. Sorry, no pics now as the bike's at the shop. http://24x7diy.com/product_info.php/products_id/78
If you don't mind spending more, these Denali D3s have a good rep, and still much cheaper than the Motolights. http://www.twistedthrottle.com/trade/productview/6158/
These may work and these are good people to deal with
http://www.electricalconnection.com/...s/dl-1watt.htm
