Question about LED Run/Turn/Brake lamps
Old 08-27-2011, 11:15 AM
BigDaddyMike's Avatar
BigDaddyMike
BigDaddyMike is offline
Default Question about LED Run/Turn/Brake lamps
I have the Genesis II from Custom Dynamics LED lamps in my turn signals front and back. I also have a Badlands load equalizer and a HD run/turn brake module to allow the turn signals to act as running and brake lights. I have noticed that although the Custom Dynamics LEDs are very bright, they are not much brighter when the brake is applied. It almost looks like the brake is always on, although there is a slight almost imperceptible difference when the brake switch is activated...any thoughts on this? I use a BAL tail light so I know the brake light switch s are operating properly.
THE FIX is in my last post here*******************
Old 08-27-2011, 11:38 AM
pworks's Avatar
pworks
pworks is offline
I installed a module called a TailStopper from Biketronics. Turn signals are NOT running lights but come to full brightness with the Bad *** brake light. Really noticable when I brake.
Old 08-27-2011, 12:41 PM
tmans's Avatar
tmans
tmans is offline
BDMike - i have an 09 FLHTCU with the HD run/turn/brake, Badlands module and LED's from Kieth at RideTimeTechnologies. the difference between the run lights, and Brake/Blink is noticeable. You may need to add a resister in line.
Old 08-27-2011, 02:59 PM
Garemlin's Avatar
Garemlin
Garemlin is offline
That is weird Mike. I have the CD clusters but use a Biketronics tailbones r/t/b and Smart Equalizer. I notice a substantial difference between run and brake. I'd say first step would be try a different r/t/b module.
Old 08-27-2011, 04:12 PM
lilricky's Avatar
lilricky
lilricky is offline
I'm rumbaing the CD r/b/t adapter set to blink 3 times before solid, there is noticeable difference when I put the brakes on.
Old 08-29-2011, 09:27 PM
BigDaddyMike
Thanks Steve, I am going to order a Biketronics unit and try it.
Old 08-29-2011, 09:59 PM
Garemlin's Avatar
Garemlin
Garemlin is offline
Phat Performance has them for a decent price.
Old 08-29-2011, 10:30 PM
WI Bob's Avatar
WI Bob
WI Bob is offline
Mike,
My set up is similar to yours with the Badlander and works very well. I will see if I can get a vid loaded here.
Old 08-29-2011, 10:56 PM
WI Bob's Avatar
WI Bob
WI Bob is offline
LED tailights with Badlanders balancer, poor VID, but you get the look
http://www.youtube.com/watch?v=an7yZQfvuvY
Old 08-29-2011, 11:07 PM
BigDaddyMike
Thanks! Great video, mine are no where near that much difference in intensity.
Quick Reply: Question about LED Run/Turn/Brake lamps
