Was there a full Harley moon this weekend?
My wife and I went on a truly enjoyable group ride thru the backroads of OH on Sunday, and Monday I woke up in the bizarro world. My handlebars have the shakes, my wife says she wants me to buy her some adjustable passenger pegs, and to top it all off, this morning I discovered a small puddle of fluid under my bike. The handlebars and the adjustable pegs I can deal with, but an unexpected oil stain is enough to send me into a mild anxiety attack. I checked all the drain holes that I've messed with recently -- no problem there. Looks like I've got some fluid dripping on my drive belt from somewhere in the vicinity of the transmission sprocket. Is there some sort of seal or bearing that is the likely culprit? Could this maybe be connected to the unusual primary/clutch noises I've been noticing for the past 1,000 miles or so? And if it is a mainshaft bearing/seal or an inner primary bearing or whatever, is it safe to ride about 7 miles to my indy?
2009 Ultra Classic, 17,000 miles, Stage1 A/C, FuelMoto Dyno-tuned slip-ons, Harley download.
Received 3,940 Likes
Sounds like the transmission shift lever shaft seal is leaking.
Look at #35 on the diagram in this link
Unfortunately gotta pull the outer and inner primary to get to it.
Check your trans fluid level and primary fluid lever before riding it again.
Kevin
Kevin
