First ride after Andrews 21 install
#31
I did the complete upgrade with the new oil pump, cam chains and a set of Andrews 21C cams over 2 years ago on my 2004 Road King, pretty much stock except a pipe and air cleaner change, Great bang for the buck. IMO if you're going in to replace the cams, might as well upgrade to the new style oil pump, cam chains and tensioners as long at it is apart. You get the Torrington bearings also kit and not that complicated to to.
#32
#33
One question, are most of you changing to true duals along with the cam upgrade. I was told that the true duals effect the low end torque but am wondering if the 21's make up for the loss.
I was in Daytona this past weekend and talked with the S&S people. If they had not sold their last set of gear drive cams I would have had them installed while I was there.
I've been looking at doing the cam upgrade for awhile now and after reading these threads I am leaning to the Andrews 21.
Ride safe
Ride safe
#35
#36
Ride safe
Ride safe
#37
#38
I know I'm resurrecting an old thread here. But I'm hoping someone can help. I just had Andrews 21 installed with a PCV and a full dyno tune in 01 stock 88 ultra classic. (only other mods are big sucker, SS powertune headers, ad VH monster round sip on's) . And although it seems to run smooth there is no bottom end torque whatsoever. My bike runs like a 4 cylinder mini van instead of a stump pulling school bus I was expecting. Everything Ive read on here and even a call to Andrews convinced me the 21 was the way to go with my Ultra for low end torque.
Before adding the 21's I was running with stock cams, big sucker, SS powertune headers, ad VH monster round's and cobra power pro auto tuner. That setup gave me way more low end torque than the new setup.So much so all the way home from the tuner I kept thinking I was in 2nd gear taking off from a dead stop. It took off smooth but just no torque. Even down shifting into 1st and 2nd felt like there was nothing there compared to when I down shifted with the stock cams.
My question those with experience... is this because of the tune? Does a tune really affect the low down torque that much? I'm just blown away that there is such a drastic difference in low down torque in the opposite direction of what I was expecting.
I will be calling the tuner on Monday to get his take. I picked it up on Friday as they were closing and didn't have a chance to call him after riding. Not to mention I needed to ride it a couple of times to digest what was really happening. I'm so bummed, all that money into new cams, dyno and PCV and I went backwards... Any advice or knowledge anyone can share would be greatly appreciated.
#39
#40
I have the same air cleaner and headers as you, but with Rinehart muffles and a Fuel Moto PCIII USB tuner. It was a noticeable improvement with the 21N cams. I wouldn't think the tune would'nt make that much difference unless you were experiencing a rough idle, decel popping, or some other anomaly that would indicate a bad air/fuel mix. I'm wondering if the cam timing is off a tooth. Did you install the cams yourself? Did your guy provide a dyno sheet?
To the best of my knowledge bike was stock everything when bought it last year except the the previous owners had the tentioners replaced with the SE hydrolic kit and added a oil cooler. I have the paperwork. No cams listed.
So here my next question... the dealer paper work for the tentioner install has adjustable pushrods, new tappets, and the tuner said there were already Torrington barings in there. Is that normal on a SE Hydro tentioner install?
