2009 ultra classic flhtcu Street Glide Rear Fender on Ultra Classic
Old 03-31-2024, 12:45 PM
ram1980's Avatar
ram1980
ram1980 is offline
Default 2009 ultra classic flhtcu Street Glide Rear Fender on Ultra Classic
Hey guys! What fenders do I need to convert a 2009 ultra classic to street glide front and rear fenders. Going for the street glide look. Thanks in advance
Old 03-31-2024, 01:55 PM
07UltraGuy's Avatar
07UltraGuy
07UltraGuy is offline
Received 5,209 Likes on 1,795 Posts
Same fenders, just minus the chrome trim and bumpers.
Old 03-31-2024, 02:20 PM
ram1980's Avatar
ram1980
ram1980 is offline
I wanted wanted the fender trim to cover the holes and get rid of the tri bar would I need different hardware if I found a cvo are stock street glide fenders.
wanted to do something like this with smoke lights and turn signal in the filers
Old 03-31-2024, 02:30 PM
07UltraGuy's Avatar
07UltraGuy
You can use that light on your current fender.
There are several filler options out there from lights to chrome/painted panels, etc.
Old 03-31-2024, 02:45 PM
ram1980's Avatar
ram1980
ram1980 is offline
So what would you suggest. Trying to make it look more like a street glide. Without a lot of drilling. I would want to keep the old fenders stock in case I sell the bike.
Old 03-31-2024, 03:36 PM
07UltraGuy's Avatar
07UltraGuy
I have no opinion or stake in your project, but to make your Ultra look more like a Street Glide, you can pull the lower fairings, remove the bag surrounds, and replace the tail light arm w/ the shorter version.
Then remove the chrome bumpers.
Note:
If you remove the chrome bumper on the rear fender, you’ll need to replace that with a hidden bracket that bolts to each bag support in place of the bumper.
The front bumper will come off and allow the chrome trim and fender light to remain without exposing any holes.
Then you’ll still have the Tourpack and associated wiring to deal with (antennas, speakers, lights).
Replacing the rear tail light assembly will also likely force you to change how the license plate mounts, and how it illuminates to keep the po-po off your tail.
Then there’s the seat and rear footboards to contend with.
Old 03-31-2024, 03:40 PM
ram1980's Avatar
ram1980
ram1980 is offline
This it what it looks like now that's a street glide seat on it. Just need to figure out the fenders with different lights.
Old 03-31-2024, 03:54 PM
07UltraGuy's Avatar
07UltraGuy
You can just replace the chrome tri-bar with a shorter version (which will use the same light housings), or you can swap it out for the Street Glide bracket w/ bullet lights.
Old 03-31-2024, 03:55 PM
ram1980's Avatar
ram1980
ram1980 is offline
What about the bottom light and fender fillers?
Old 04-01-2024, 05:41 PM
ram1980's Avatar
ram1980
ram1980 is offline
Found what I need. Does anyone know the part number for the medallion that cover the hole when you remove the lower tail light. And also the front fender when you remove the fender light.to cover the indent in the fender where the light was.
Quick Reply: 2009 ultra classic flhtcu Street Glide Rear Fender on Ultra Classic
