Checked mine. One's gone, and the other is a little loose (can spin the washer). I've accumulated HD bolts over the years, so I might be able to fix this without a trip to the dealer. Looks like it is a 5/16. Can someone please confirm this, and also tell me the length? Thanks.
I thought something was up. I tried a 2" & could just get so far. I've learned over the years (I'm 64 & have been a novice wrench for about 52 of those years) when it don't want to go, don't make it go. I'll try a 1-1/2 tomorrow.
Thanks again pdzani
Hey Beary, could you clarify which bolt your reff to that if loose will cause a leak? Odd that a hanger bolt missing or loose would cause a leak, that would imply this bolt is threaded all the way thru to the fluid reservoir? that's a weird design flaw don't you think?
I just experienced the same thing on my 2010 Ultra with 9200 miles. I ended up pulling the tranny cover so I could get to those two bolts to tighten them.
