Check your transmission exhaust hanger bolts
#81
I stumbled across this thread while trying to figure out why my exhaust mounting bracket was bolted to my header pipe but not to the transmission (not a very effective mounting bracket). I know I didn't skip those bolts a couple years ago when I reinstalled my exhaust after having pulled it off of my '07 Street Glide. I'm switching to the Fuel Moto E-Series 2-into-1 and will get that bracket remounted.
Like a few others have mentioned, there have been a number of times when I could smell the distinct odor of tranny fluid burning during a long ride, but I could never identify the source. There haven't been any drops on the garage floor and the fluid level has never dropped a noticeable amount.
Thanks to all you folks for providing info around this issue and the associated service bulletin. I'll be adding some loctite and torquing those bolts accordingly, once I replace them.
On a similar note, as I was pulling off my stock headers, I noticed that the tab that connects to the crossover had also broken. I'm assuming the stress was shifted from the transmission exhaust mounting bracket, after the bolts backed out and disappeared somewhere, to that tab. That means my exhaust was held up by the muffler mounts underneath the saddlebags and the flange nuts, which likely explains the annoying squeak that the muffler mounts made at idle.
#82
I was changing the rear tire on my Ultra today and noticed that the two transmission exhaust hanger bolts were very loose. No oil leaks. Tightened up those two bolts (actually removed them and placed Loctite on them), and tightened up the other six bolts. I've been trying to track down what sounds like an intermittent rattle and I'm hoping this was the cause.
#83
Checked mine. One's gone, and the other is a little loose (can spin the washer). I've accumulated HD bolts over the years, so I might be able to fix this without a trip to the dealer. Looks like it is a 5/16. Can someone please confirm this, and also tell me the length? Thanks.
Now I check them my self
#84
Returned from a day trip to Little River Canyon a couple of weeks ago and after having my toe shifter vibrate off (another story in itself) I put the bike in the garage and the next morning I had a nice little puddle of transmission fluid on the floor under the bike. Both of my bolts had backed out, luckily they were still hanging on by a couple of threads. I tightened them up, added more fluid, and am good to go. Just another thing to add to my checklist before a ride.
#85
just experienced the same thing on my 2003 Ultra.
Is it just enough to tighten those bolts or do I need a new gasket?
http://partsfinder.onlinemicrofiche....0SIDE%20COVERS
#87
#88
#90
No, you can check the forum here for the correct size but cutting the end off a hex key and using that in a ring spanner will get you the room you need, or a screwdriver bit.
