Check your transmission exhaust hanger bolts
This is a public service announce ment: Check you bolts.
I had a little leak dripping off my oil plug, so thinking my o-ring was worn, I replaced it. In the process, I stripped the bolt, but that is another story. When I took the bike to the shop to have the pan checked, oil was dripping a lot, but not from the bolt. The mechanic knew what the problem was even before he looked, it was the two bottom bolts on the transmission cover that hold exhaust hanger. He said he checks every bike that comes in and most need the bolts tightened. So go check your bolts befoe the oil starts to leak.
Now I have to figure out how to clean the frame under the pan. Looks like I need a teeny weeny brush.
Beary
Beary
I have had my bolts back out and the vibration ended up cracking the exhaust hanger on my 02 RK. I checked my ulta a month ago and they were starting to back out as well, replaced with grade 8 bolts and lock washers. The allen bolts just have a flat washer. Put the blue lock tite on as well.
Experienced the same thing on my '06 and on my brother's '09. The '09 just leaked a little, obvious trans fluid. The '06 actully had issues with the neutral light switch, becuasue the gearset was "floating" in the housing. Definately worth a check at the next maintenance interval, guess they count as critical fasteners.
As far as cleaning the oil from the frame, after every oil change, I spray Greased Lightening for Garages (purple bottle) on the whole bottom of the bike, then give the bike a wash. You could also look at using some carb or brake cleaner, use the little tube to under there real good, then wash everything off.
Beary
Beary
