I was checking my Ultra Classic rear tire pressure, while I open the the valve stem cap I hear air leak, then I shake the stem and the inside brass pipe comes out.
Reason: add pic
When did you replace your front tire and was it done at the same place as the back? You might want to consider replacing it as well. I seem to remember that a few years back a slug of faulty valve stems came into NA from a certain Asian country. It may be that the person who did your tires had some of these around their shop.
Thank you, I will replace the front valve stem also.
I will put the metal one but not the 90 degree valve stem, because 90 degree valve stem not available yet here.
