Anyone powering their GPS from the cig lighter?
Old 10-03-2011, 10:47 AM
steelhead's Avatar
steelhead
steelhead is offline
Default Anyone powering their GPS from the cig lighter?
Recently traded in my RKC for a CVO Street Glide. On the RK, I had power for the GPS hardwired and then used a quick connect plug when I wanted to pull it off the bike. On the Street Glide I have a cig lighter and figured it would be easy to simply wire it with a lighter power plug. That was until I read the owner's manual that said do not use the lighter for a power supply.
Is this just typical owner's manual warning BS or is there a reason not to? Also, does anyone know if the cig lighter is always hot (powered) or if the bike has to be on or turned to ACC?
Old 10-03-2011, 10:55 AM
Hecklerboy's Avatar
Hecklerboy
Hecklerboy is offline
I was wondering the samething. The owners manual says it will damage the cig lighter and cause it not to work properly.
Only thing I can see it causing is the cig lighter not staying in properly. Which doesn't bother me since I don't smoke.
I plugged my GPS into the cig lighter and it worked fine.
And yes the bike has to be turned on for the cig lighter to work.
I'm thinking it's just HD covering their *** just in case it does damage it.
Old 10-03-2011, 11:03 AM
TomWoodgeard's Avatar
TomWoodgeard
TomWoodgeard is offline
I've been powering my Zumo with the lighter outlet for years, using the West Marine plug. No problems
Old 10-03-2011, 11:08 AM
gmurdock's Avatar
gmurdock
gmurdock is offline
I have used mine for a couple of different GPSs. Used it from Oralndo FL to Pigeon Forge Tenn in poring rain laast year. No problem. 1 Magellan & 1 Lowrance. I have also used it to charge my Iphone.
Old 10-03-2011, 11:16 AM
Kugie's HOG's Avatar
Kugie's HOG
Kugie's HOG is offline
I have my GPS wired to the cig lighter & have had no problems at all.
Old 10-03-2011, 11:23 AM
DeafUltra's Avatar
DeafUltra
DeafUltra is offline
Have Garmin Zumo 550 and do not plug in the Cig Lighter. My mechanic/installer had it set up very clean using the "little" plug by the CD/radio player as the wiring goes through inside my fairing all the way up to left handlebar grip.
Thorey
Old 10-03-2011, 11:27 AM
AnotherBlackSG's Avatar
AnotherBlackSG
AnotherBlackSG is offline
Yup, my Garmin is plugged into the lighter and I've never had any problems with it.
Old 10-03-2011, 11:34 AM
danzio's Avatar
danzio
danzio is offline
I use a USB adapter in the cig plug to operate my GPS or Phone or anything else with a USB plug. No problems.
Old 10-03-2011, 11:39 AM
PFWiz's Avatar
PFWiz
PFWiz is offline
I always use my lighter socket to power my GPS.
What other than possible exposure to the elements is the difference between a car and motorcycle cigarette lighter? Hell, I run everything off the car sockets, Laptops, CD players, MP3 Players, GPS, Radar Dectors...ect
I think this is another one of those HD does not recommend using Synthetics in your bike kind of thing.
Old 10-03-2011, 12:00 PM
casique's Avatar
casique
casique is offline
Be careful when you do a full turn to the left, some plugs can impact the tank.
Quick Reply: Anyone powering their GPS from the cig lighter?
