S&S compression release cams
I am looking at purchasing either the S&S 510C or 585C compression release cams in my 2010rkc with 96ci engine. Is anyone running either of these cams and what is your opinion of them. I want more low end torque for two up riding, not really concerned with more hp. Also these cams seem like a great idea so that you dont have to install the compression release valve in the heads.
I asked my mech about those and he said they have a very high failure rate. Not a good idea to have moving parts like that on an internal engine component. Just parroting what he said but it makes sense.
It was a hypothetical question anyway because my 103 has compression release. I went with the S&S 510's on his recommendation. We were both pleased and impressed with the outcome. Starts up real easy.
Woolly - Would be curious to know your mechanics reference point for the failure. I haven't heard anything close to that. In fact, the VRod uses the same type of release from the factory. This is not new technology, it's been around for a long time (before the VRod too).
Zach
Originally Posted by biggzed
I don't think I would recommend either in a stock compression 96". You may end up with not enough cranking pressure for the bike to start. The ECM needs to see a minimum cranking PSI in order to fire. People have had trouble with those Easy Starts in low compression applications.
Zach
Zach
Zach
Zach
Zach
Of course I am sure there are dozens out there running these cams with no problems. It's not an issue for bikes with automatic compression release. Might be worth putting that in your bike if thinking about some aggressive cams. Or getting the C models and see how long they last. I would be curious to know.
Anyway, you can look him up on the web. Danny's Cycle Shop in Montgomery, TX. He's been doing aftermarket Harley work for a long time.
