changing fork seals or just oil
I have 44000 on my 09 road glide. The manual says I should change the fork oil at 50,000. This question is for the diy guys out there. Did you just change the oil or did you replace the seals when you change the fork oil?? there is no leakage at this time. I am thinking of changing the oil and seals myself because the dealer wants $229.00 to do the job.They said the the techs say to change it sooner if you ride the all types of weather. Dont shoot me I am just saying what I was told. This would be a project when I have to put the bike to sleep. Any input is appreciated.
Thanks
Jrbean
Thanks
Jrbean
Check the top of your forks ( under the cowbells) if you see streaking of fork oil, then the seals could use servicing.
what kills seals is dirt landing on the forks and working up and down abrading the seal lips, and it only gets worse.
bikes with rubber gaiters, the fork seals last a long time, our bikes use cowbells and the do work quite well to keep the dirt off
my 88 and 95 both have factory seals, 80000+ on both of them, and the 88 is an fxr, no gaiters or cowbells
mike
mike
If I was you I would look at Progressive Monotubes.
Mine cost less than $300, I installed them myself and they remove the need to change the oil. The best bit is that the front end control is greatly improved and brake dive is reduced.
Of you are happy with the stock ride then I would just change the oil and not worry about the seals.
