Odyssey Battery
Odyssey Battery
I just put a Odyssey battery in my 09 Street Glide. From my research online it is supposed to be a "direct replacement", but I knew it would take a litle tweaking since it goes in sideways with female terminals toward the front of the bike. Holy crap, getting the positive terminal connected was a real PITA. The only way to get it on is to force the positive cable where you need it while praying you dont short anything in the process. The negative (ground) side was no big deal. Gonna take a ride later, and only time will tell how good the battery is, but it sure fires up good now.
Is anyone else running a odyssey battery and did you have the same issues getting it in (exercise in patience) or am i a dim bulb?
I have been using odyssey batteries for years and always on a battery maintainer.They seem to last me about 5-7 years.Odyssey says that a deltran battery tender does not work on their batteries,they have one that is for their batteries only. I don't know what the difference is but i did buy 2 for my batteries and never had a problem so far.
I had one fail- suddenly internal open...
stranded.
free replacement under warranty...internally shorted and could have burned done the bike and the house- luckily I was in the garage and heard it bubbling away.
bolt cutters on the battery cables and I got it out and contained in a barrel
got my money back
I don't think they can stand up to vibration, and a deka is 1/2 the price
I use agm batteries now
mike
stranded.
got my money back
mike
The MoCo doesn't manufacture batteries (I'm sure most know that already) and stock Harley batteries are re-branded Dekka batteries made by East Penn Manufacturing Company. Buying them under the Dekka name will save you some money over the Dealer. Also, if you have a Batteries Plus store in your area they have many AGM (sealed & maintenance free) 300 to 400 CCA batteries for Harleys in the hundred dollar price range.
There's no battery that last longer than a year or so in my hardtail so I just buy those $80 AGMs you can find at local auto parts stores or even Walmart. As long as the CCA is 300 or better they work fine, until they open fault or short out.
After the last one failed I looked at the new Lithium Iron batteries (small and very lightweight) made by Ballistic and Shorai. With the CCA needed for a Harley the size is about the same but the weight is way down. They are also supposed to be more vibration resistant.
http://www.ballisticparts.com/produc...ies/12cell.php
http://www.shoraipower.com/c-1-batteries.aspx
http://www.webbikeworld.com/motorcyc...le-battery.htm
In the end I just went with another cheap AGM battery as the price on the LIBs (over the counter) was pretty high, at around $260. (Could probably do better online, but I was down and needed a battery right away.) But the whole story on these batteries hasn't been written yet as they are only about two years old in motorcycle use.
And I almost hate to repeat this as its unfounded but I read on another forum that one guy said he knew another guy (I know, right?) that had a Harley burn to the ground with one of these LIBs.
So I think I'll wait another year and look at them again. LOL!
Glad you had luck with Yuasa because I've put two in my RC in the last two years. Last one internally shorted out 50 miles from help and no cell service. Back to Dekka/OEM and no problems...
