redshift 575 in a stock 2007 96 inch ?
OK, I was all set to put a Andrews 48H in and the local wrench wants me to go with the redshift 575. I have hi flow air cleaner, American Custom pipes no baffels and Thundermax tuner. It looks like a lot of cam for a stock build ? He claims it will be fine. Anybody have any experience with any thing close to this set up ? Thanks ...
Thanks Old Guy, makes me feel better knowing you are happy with that cam. I have read, in some posts, that they cause a lot of valve train noise? Any noticable noise ? Just one more thing. I know my bike is heavier and geared a little different but I was also wondering what kind of gas milage you are getting ? The intake opening is so much longer than other bolt in cams in its class, just wondering. I do like the fact that there is a map that will bring me pretty close after installation. As always, thank you for your time...
I run Zippers Redshift 575's in my 08 Ultra 96" with Zippers hi-flow A/C, D&D Fatcats 2-1, TTS Mastertune and I re-geared it with a EVO 49T ring gear kit. Was a little tough to get the tune dialed in, but it runs great. I'm either going to go with a 103 with dished pistons and keep the same cam (which is considered Zippers sleeper 103) or swap out to Tman 555's when I go 103
