1990 flhtcu inner fairing?
Old 11-21-2011, 04:32 PM
sgtrod91's Avatar
sgtrod91
sgtrod91 is offline
Default 1990 flhtcu inner fairing?
Where can I find a inner fairing for a 1990 FLHTCU, been looking on ebay with no luck.
Also, anyone makes replacement inner fairings?
Old 11-21-2011, 04:34 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
it's gonna be tough --- swap meets, keep watching ebay, post on the wanted forum here.
wreck damage?
mike
Old 11-21-2011, 04:51 PM
sgtrod91's Avatar
sgtrod91
sgtrod91 is offline
wreck damage?
mike
no, I just bought a 1990 ultra classic , inner fairing has a huge crack/ hole below the radio hole.
Old 11-21-2011, 05:49 PM
93flhtcu's Avatar
93flhtcu
93flhtcu is offline
I had an 1993 ultra . I wrecked my bike back in 1998 and they put a 1994 inner fairing on my bike. I think the fairing is the same on your 1990. In 1994 they changed the fairing to include an extra switch for accessories. I believe 1994 thru 1996 or 1997 should fit. You will have to buy a rocker switch to fit the extra hole.That is what I had to do . Check your local dealer for part numbers on the inner fairing and see what years the part no. remains the same.
Old 11-21-2011, 07:34 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
naw, the fairing change going into 1996, so he needs a 1995 or earlier...
OP think about a repair, it may be easier
mike
Old 11-21-2011, 09:32 PM
Ultra89Rider's Avatar
Ultra89Rider
Ultra89Rider is offline
You can use the later inner fairing, but if you try to use the later fairing (58497-96), you will find you will need to change a lot of other parts.
The first things that will change is the outer fairing and windshield. Next, the top of the triple tree is different. The ignition and fork lock changed.
Those are the most obvious. I know because I did it.
So it may be better to fins a way to fix the older one if you cant find a direct replacement.
Old 04-21-2016, 05:11 AM
eddie4451's Avatar
eddie4451
eddie4451 is offline
I know this post is old but I have an inner fairing off a 1993
Old 04-12-2018, 03:46 PM
Rmlotz87's Avatar
Rmlotz87
Rmlotz87 is offline
Stage I
Default 1993 inner Fairing
How much are you asking for that 1993 inner fairing my buddy just got a 1994 Flhtcu from his pops when he passed away and the fairing is pretty messed up. I'm helping him restore his dad's bike? My direct email is Rmlotz87@gmail.com
MikeRock1210
04-22-2019 01:53 PM
JohnNMiami
02-13-2017 10:44 AM
jimsflh
02-09-2010 03:46 PM
Garrison1383
06-19-2006 05:41 PM
wjl24
06-07-2006 01:04 PM
Quick Reply: 1990 flhtcu inner fairing?
