Gotta Whistle Sound
Old 11-22-2011, 02:51 PM
SugsPa's Avatar
SugsPa
SugsPa is offline
Default Gotta Whistle Sound
My 07 Ultra sometimes makes a brief whistle sound when I shut it off. It has a K&N air cleaner and V&H true duals. Other than that it's stock. Kinda sounds like a suckin in whistle instead of a blowin out whistle. It runs fine, just wondering if anyone has heard this before or have any ideas what it may be.
Thanks,
SugsPa
Old 11-22-2011, 08:40 PM
X Iron Butt's Avatar
X Iron Butt
X Iron Butt is offline
It is normal mine does it too. exhaust valve is open and it is sucking back through the exhaust. One cyl is coming up on compression and the other is on exhaust. With no fire on comp cyl the comp piston is forced back down and the ex piston sucks air in. Same pipes. Keeps the spiders on their toes.
Old 11-22-2011, 09:02 PM
FUJILICIOUS's Avatar
FUJILICIOUS
FUJILICIOUS is offline
...so thats what it is. Mine does it too but only since going to a stage 1. Never really affected anything so I just chalked it up to another one of those "normal" sounds. I just tell the chicks that the bike is whistling at them. Now I know.
Old 11-22-2011, 09:54 PM
fenderzig's Avatar
fenderzig
fenderzig is offline
haha Mine does it too...I always look around to see if my buddies hear it because it sounds funny.
Old 11-22-2011, 10:19 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,532 Likes on 3,784 Posts
Just my opinion but I think its the compression from the piston stopping at half compression and leaking back around the ring gaps, down into the crank case and up and out thru the ventilation breather system. The ventilation valves in the later model twin cam engines are rubber one way free flowing out poppet valves. The intake and exhaust valve if correct totally seal and will not leak by so it cannot be in exhaust pipe or intake throttle body. Besides the throttle body is close to air tight since the butterfly seats very well and the idle pintol valve from the IAC closes to prevent run-on and only opens and reset itself on the next key on. The suck-in in whistle is actually a sneeze and is the noise of air coming by the ring gaps echoing into crank case up and out the vents into the air filter.
Nice album Iron B on the starter gear
Old 11-23-2011, 08:56 AM
X Iron Butt
I definitley hear the sound through my left pipe (true duals like the OP). It is a short sucking in sound not blowing out. When the front cyl hits the compression and doesn't fire the engine goes backwards a half rev or so. With the front on comp the rear is on ex and right before TDC with the exhaust valve open and piston now going back down. Result is suck back through the exhaust. Almost straight through pipe so no restriction.
Thanks I want to post the starter gear pics on the original thread but I can't (havent had time) to hack how to post pics that are not thumbnails.
BTW All compensator knocking is still gone.
Old 11-23-2011, 09:37 AM
equandt's Avatar
equandt
equandt is offline
Its pretty normal. My '02 does it as well. FYI - It's got a 95" BB kit and a S&S 510G cam and all the related goodies. It runs like a raped ape, even with the whistle.
HD must have resolved the issues creating the whistle with the new framed bikes because my '10 doesn't do it.
Old 11-23-2011, 10:31 AM
TUCCI's Avatar
TUCCI
TUCCI is offline
Wow those pre 11' bikes sure had some weird peculiarities the list goes on and on: compensator, chain tensioners, what else hell who knows quit a love affair we have with these beasts huhh?
Old 11-23-2011, 10:38 AM
Ribitt's Avatar
Ribitt
Ribitt is offline
Cool
when my 07 ultra does it it is time to clean the air filter.
Flyinphil
11-08-2015 11:05 AM
Timmer
2014-2023 Touring Models
11
09-23-2015 06:02 PM
MAX EVO
VRSC Models
11-13-2008 07:36 AM
flyslow
04-24-2007 08:19 PM
HDNY1
04-13-2006 06:15 PM
Quick Reply: Gotta Whistle Sound
