08 flhx tire and wheel sizes
I have a 08 flhx with 16 wheels. I'm wanting to buy new wheels and tires and I'm looking at going with a 18 in front but I want to go with a wider tire in the rear what is the widest tire and rim can I use in 16 and 18 and between the two which of those are the widest with out rubbing my belt guard.
Thanks
Thanks
On the rear you can go with a 16 x 3.5" with a 150/80-16 or a 18 x 4.25" with a 150/70-18. Both will fit without any mods but the 18" is around 1/2" taller if that matters to you. We carry a lot of the top wheel manufactures so if you have any questions about pricing, fitment, etc just let us know.
I have just bought a Duece alloy rear wheel to try squeezing into my bike, which is 4.5" x 17" and takes a 160/70 tyre. That's an alternative and as it is a solid disc you can fit whatever style of front you fancy. I prefer Avon tyres and their Storm in that size has a higher load rating than the stock Harley tyres of 79. It is likely to be a close fit!
My Venom 150/80 x 16 is supposed to be 150mm wide fitted, but actually measures 153mm, or 1/8" wider than it should be. They also make a V rated tyre of the same nominal size, which I understand is a little wider.
So check the website of your preferred brand, but allow a little extra 'just in case'!
Red-line
01-05-2013 01:30 PM
jpnelson1978
10-18-2009 03:45 AM
