homemade tool for alignment ogf ignition switch touring
Here's a tool I made. I needed something that I could use to ride my bike while the **** was removed for a few days so I made this tool.
This tool is made from a 1/4-20 x 4" stainless bolt. Cut the head off, hammer/grind/file the shank into shape, use the threaded end to attach a nylon centering bushing, fender washer for depth control, and plastic handle.
Got everything needed at a local home center for less than $10.00.
Obviously this took a little longer to make than simply flattening and bending a piece of tubing, but I enjoy making "stuff" so the time was not an issue. If you need something quick and right now, the tubing tool fits the bill.
You can also use a screwdriver and a flashlight if you have to.
Ken from HomemadeTools.net here. We appreciate the creativity and ingenious solutions found everywhere builders of homemade tools congregate.
Great little switch aligner; a simple and elegant solution. As a rider myself (Triumph & Ducati nowadays), I know how handy this could be...
Added to our database (always with full credit and linked to the original post) here: http://www.homemadetools.net/harley-...alignment-tool
Ken
The following 2 users liked this post by wildey:
BrownSanta (05-11-2016),
wmprof (12-03-2016)
Nevermind. I got a smaller screwdriver & a better flashlight. Piece of cake! It was blatantly obvious once I could see everything down there. Thanks!
