Amsoil Vs Red Line and air bubbles P2
I went back to Red Line 20w-60w after reading Amsoil Tech responce.
None of the conditions they stated were even close,
"Over / Under Filling" WTF I check my oil hot everyother ride
"Cold Temp / Water" - I live in Calif. oil temp gauge reads 260deg.
This is my thread, with pic.
https://www.hdforums.com/forum/touring-models/710262-amsoil-new-to-me-air-in-oil.html
Vincent;
Air bubbles can also be referred to as the oil’s foaming tendencies. This is a measured performance property and the results below show that AMSOIL 20W50 Motorcycle retains no air in any of the three sequences the test includes:
Foam (ASTM D-892, Sequence I, II & III)
Air is commonly mixed with the oil, and the test tells how long it takes for the air to separate out under lab conditions. You may find this varies a bit under use conditions and more air is temporarily trapped in the oil under certain conditions, including cold temperatures, over filling or under filling the reservoir, and/or condensation (water) accumulation in the oil.
Byron Selbrede
Technical Services
AMSOIL INC.
ADDRESS: 1 AMSOIL Center, Superior, WI 54880
E-MAIL:bselbrede@amsoil.com
PHONE:715-392-7101
FAX:715-392-3097
Vincent;
0/0/0
Byron Selbrede
Technical Services
AMSOIL INC.
PHONE:715-392-7101
FAX:715-392-3097
I've found those bubles on my HD stick with any oil. Redline too. I've tried most of the high-end oils from Mobil 1 to AMSOIL, Redline, Royal Purple, etc... and they ALL had those bubbles. So, I was looking at the stick with all the indents and writing and tried a smooth heavy gauge wire. Guess what? No bubbles. It's the stick, not the oil
Harley San Jose stocks 20W60 and they recomend using it... I never ran an oil cooler, even on my trips to Las Vegas , Ariz., Texas etc.. I should...
http://www.redlineoil.com/product.aspx?pid=111&pcid=21
Amsoil responce "Cold" - that was the kicker for me - cold when do you ever check your oil cold ? and cold in Calif. when ?
The stick , LoL - Amsoil could have covered that in there responce as well - plastic Vs metal - hmmmmmm
For me I just never ever seen air bubbles, my '07 FLHX sold it at 60k miles and changed the oil every 3k miles , never saw it , when I ran Mobil 1, and Red Line no air bubbles, so for me it's just a mental thing, I do not like to see bubbles in my oil....
Last word: Redline States:
"All products are completely compatible with other conventional and synthetic motor oils"
I could not find it on the bottle of the Amsoil or Mobil 1 , never know when you need to add a quart in lets say Gerlach, NV - not that it would stop me from puting any tpe of oil stuck in the middle of BFE
FWIW, this is directly from the Amsoil website (I assume similar from M1 as well) so you won't have any issues on mixing oil should you need to.
MIXING AMSOIL
AMSOIL Synthetic 20W-50 Motorcycle Oil is compatible with conventional and synthetic motor oils; however, mixing oils may shorten the oil life expectancy and reduce the performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed.
Aftermarket oil additives are not recommended for use with AMSOIL motorcycle oil.
http://www.amsoil.com/storefront/mcv.aspx
MIXING AMSOIL
They should put this on thier bottles/ never saw this on the web site:
Agree: just sharing my experience with Amsoil after 2k miles
I tried Amsoil about 5 years ago. Like you I wasn't very happy with it. I switched over to the Redline 20/60 and never looked back. Great oil for hot weather riding. I have made plenty of trips across the desert with very good results. One thing I noticed right away is that the Redline holds it's viscosity a lot better then any other oil I had run.
