First time Harley owner and forum user. I could sure use a little help on my 1998 Road King. When I turn on either left or right turn signal, both rears blink at same time. Fronts work properly. Any help would be appreciated.
Hummm...I would start with checking the basics.....bulbs, if the original flasher replace it, check the tail section wiring for any abnormalities like shorted wiring to include removing each bulb and inspecting the bulb sockets...in the interim others will chime in with other perspectives.
But I was thinking of getting the HD run,stop, turn kit that comes with lens and plug in harness, any thoughts.
That sound good, but I need to figure out what is making both lights flash at the same time befor I get the kit. Thanks.
I have the kit and love it. I think you might as well go ahead and get it and follow the instructions. It will probably solve your issue at the same time as you'll find the culprit and fix it when installing the kit.
