PCv issue?
PCv issue?
Hi all,
I have a FLHTP (Electra Glide Police) 2011.
Got the package from fuel moto (Jackpot, fuel moto breather and pcv)... I was very happy with this setup on my 08 FLHRC...
Anyway... I was having an issue on low RPM, when I give it full throttle, the bike sputters or sort of hicups and i get a bit of back fire...
So I did a dyno on it hoping to get it fixed, it just made it worse...
Now, the PCv came with a map from Fuel Moto, my question is, are these maps suitable for both European spec HDs as well as American specs? or is there a difference?
Has anyone had similar issues?
I disconnected the PCv and the bike ran fine... so it is definitely the PCv.
any advise or tips would be highly appreciated... I also contacted Jamie from Fuel Moto and hoping for a solution otherwise it just might be a faulty unit :S
Hi all,
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Interesting, Mine has the same problem, had the hick-up put it on a dyno and now runs worse. Took the pcv off the bike it runs perfect. Now that its winter cant do anything till spring but will be contacting Jamie since I purchased it from him. Have not been happy with the pcv from day one. pc111 was great on the 2001 Road King. (?)
Hi all,
Let us know how this turns out.
Update.... been working on this issue non stop...
Believe it or not, it was the HD Dealer that did the installation for me (PCv, Jackpots and FM AC)... guess what i just found...............
The O2 sensors where still connected!!!
Part of the testing we did to find out of it was a problem with the PCv was to load ZERO values into it... and yes, it was still cutting off when i give it full throttle at low RPM. so i finally disconnected the PCV for now...
Would having the PCv with the O2 sensors connected cause all these problems? I emailed Jamie... lets see... tomorrow morning i am Dynoing it again... will update you!
I am running without the PCv now and the bike is fine...
This is so frustrating
I'm not positive on this but I don't think the PCV is designed to run in conjunction with the O2 sensors. I think the PCV will feed O2 values to the ECU in lieu of the O2 sensors. Now, these values will be based solely on the map loaded into the PCV and they won't adjust unless you get the auto tuner.
I had an 09 Streetbob with a PCV from Fuel Moto. I plugged my O2 ports in the pipes and capped off my O2 sensor wires and the bike ran perfectly with just the PCV's map. I would guess that is your problem but wait to get confirmation from someone else as I'm not positive
If it isn't too late, call FM before letting that dealer mess with your bike again!
