Harmon Kardon firmware and amplifier
Trying to get clarification. I'm hearing that when you get the new Boom speakers that you don't need an amplifier because the dealer can unlock certain aspects of the HK radio. Is this just a firmware update or does the factory radio have more power on reserve that will blow the factory speakers?
Location: Western Illinois, land of bad roads, and corrupt politicians
I'm not sure what you're asking.
If you just replace your stock speakers, you don't need to do anything to the radio. The speakers are just better than the stock ones.
If you are adding rear speakers, you need to have the radio flashed at the dealer to turn on the fader for the rears.
Received 47,785 Likes
http://www.harley-davidson.com/en_US...io-system.html
You can find the latest firmware update at the link listed below. Don't know if you have done this yet but it may have some bearing on your issues you are seeking. Just a thought.
If you add the current Boom amp, there is a download to change the equalization in the AMP, not the HK head unit.
Also, there is a download used if you add the HD saddlebag speakers for the HK head unit. What the download does is open to question--whether it changes the head unit's sound, or simply adds a four-speaker/fader control is open to question.
Bottom line, there is no information that there is any download to change the HK head unit on an RG or EG Ultra absent the addition of an HK amp (which doesn't change the HK head unit, only the amp). And the HK saddlebag lid speaker addition isn't offered for OEM four-speaker set-ups like that of the Ultras; and, whether the download used for the saddlebag speaker kit is useful for an Ultra (front and tour pak speakers) is unknown.
Carl
