Help With a Cam for a TC88
Hey guys, I'm new to the forum and was wondering if you could help me out with a question. Im looking at putting in the new SE Hydraulic Cam Upgrade and while I am in thinking about upgrading my cams. The local stealer is pushing 211's but from everything that I am reading the 204's or Andrews 21 or 26 would be better. All the data I have says that the 211's will be better in the long haul if I go 95, which I want to do but can't afford right now. I would like to stay HD if possible because I have some points, gift cards, and such that will ease the hurt.
The bike is a stock 05 Electra Glide Classic that I bought used. Stage 1 kit, pipes from unknown manufacturer, and Power Commander. I know the cams won't do much but I'm just curious to what you guys say.
Cray: You need to provide one key component that will help you in your decision, and help those that are willing to offer their opinions. That key component is stating what it is your looking for. Do you want bottom end grunt, do you want it kicking in and performing at it's optimum in the mid range, or do you want a high end cam? Without that information, all you'll get is a lot of opinions that may or may not be useful to you.
I wanted a cam that performed at its optimum in the mid range. I am not into seeing who can hit 60 mph the fastest off the line while riding with my buddies. I also felt that my bike gave me all I needed for low end torque off the line. I felt though that it lacked in "passing power" while cruising in 5th gear at 60-65 mph. Thus, I chose the SE211. It was perfect for me, and I in fact did get some extra low end grunt out of it that was unexpected. It's not as sexy as a lot of cams out there, and there are many to choose from, but it was a mild mod that gave me a lot of bang for my buck. My point is that I first narrowed my search down that fell within the range of what my desired result was. Then I made my choice based on a number of other factors.
Decide what range you want to see most affected by your mod, and then ask questions and do research on the net. Guys here will help, and the more educated you get yourself the better they'll be able to help you. There's a number of websites that give a very compresnsive breakdown of cams and their specs. With a little reading, you'll quickly understand how each cam will effect the performance of your bike as it currently sits based on what you're looking for.
Thats the thing... I don't know. I'm young but drive like a grandpa. Yeah I like to get on it now and again taking off around town but I don't run over 80 on the interstate. Mostly around town and back roads. I would like to twist on the throttle on the interstate and pass up cars but the stock cam does good enough right now. My wife rides with me half the time and we are just cruising enjoying the day.
You mentioned that you prefer to stay with Harley parts due to the fact that you have points that you'd like to use. If that's the case, the SE203 and SE204 cams work very well with a 88TC. They're mild (the advantage of which can't be overstated) but will give you an appreciable difference in the feel of your bike. I am sure that others might chime in with greater experience than I can offer, and those too will be worhty of consideration.
Good luck to you. I'd love to hear later what you chose and of the difference it made in your ride.
I can't say enough good things about my Andrew's 21 cam. I have no intentions to go to a 95" motor so this cam works great. Pull like a locomotive down low were I wanted it. And it doesn't fall off as fast as some will make you believe. Great power in the RPM range that I ride in. My bike with this cam easily keeps up (or beats) with all my friends stage 1 96" bikes until about 65 or 70 mph. I didn't buy it as a race cam. Rode the mountains with it last summer an it gave me great power with all the climbs. Greatly reduces the amount of downshifting required compared to stock.
So if you are looking for good power for all of your everyday riding I recommend the 21.
