Why doesn't the manual tell you to prime (FILL) the oil filter?
Old 12-12-2011, 07:57 PM
alphadog001's Avatar
alphadog001
alphadog001 is offline
Default Why doesn't the manual tell you to prime (FILL) the oil filter?
I have always primed (filled) the oil filter when doing an oil change. But the 09 and up service manuals don't tell you do do this. Is there a reason why the newer twin cams don't need it? Any thoughts?
Old 12-12-2011, 08:01 PM
jjnoble's Avatar
jjnoble
jjnoble is offline
It makes a big enough mess taking it off, why do that in reverse?
piesik650's Avatar
piesik650
piesik650 is offline
I would think you would spill most of it before u got it on. and when u drain your oil there is still some in the sump during startup I wouldn't be worried about it. at least I don't.
Old 12-12-2011, 08:11 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
Used to in the vertical mounted oil filters- not any more.
start it, get oil pressure up before putting the motor under load
mike
fxdwg_rugby's Avatar
fxdwg_rugby
fxdwg_rugby is offline
If you change your oil on the kick stand, when you prime the filter like you should, it wont spill....don't over fill.
Old 12-12-2011, 08:18 PM
speedwaysteve's Avatar
speedwaysteve
speedwaysteve is offline
I take off the plug wires crank the motor till the oil light goes off,the reconnect them start it up,guess that fills the filter before start up.dont know if it makes a diffence but something i awlays done
Old 12-12-2011, 08:38 PM
Dionicio's Avatar
Dionicio
Dionicio is offline
+1....I do mine the same as You, and no oil spills out.
Old 12-12-2011, 08:44 PM
Jinks's Avatar
Jinks
Jinks is offline
Same reason no other motor needs it. There's enough oil residue to safely start the motor & build pressure when the filter fills normally, if you're mature enough to let it idle for a few seconds.
Old 12-12-2011, 09:07 PM
drukanfu's Avatar
drukanfu
drukanfu is offline
I don't want to steal the thread, but i've read some where that taking the plug wires off, you stand a very good chance of smok'in your coil. And if it is true, maybe save somebody from really damaging their coil because of over maintenance !
As far as not filling your oil filter because it could damage your motor is so dam nit-picky and extremely **** it's amazing those members can sh*t once a week !
Old 12-12-2011, 09:12 PM
A Seabee's Avatar
A Seabee
A Seabee is offline
I know I'm out of my community, but my '12 Iron manual still has instructions for filling the filter when changing...
Quick Reply: Why doesn't the manual tell you to prime (FILL) the oil filter?
