How To Change Brake Fluid?
Old 12-20-2011, 07:14 PM
drspencer's Avatar
drspencer
drspencer is offline
Default How To Change Brake Fluid?
Can someone please give me a 'how-to' on changing brake fluid on a non-ABS bike?
Is this a one man job?
Is there a preferred type of brake fluid to use?
Thanks
Old 12-20-2011, 07:33 PM
Talldog's Avatar
Talldog
Talldog is offline
Need to read your manual to see what type of fluid to use, my 2012 Ultra uses Dot 4, but have no idea what your bike uses.
Get yourself a service manual and buy a Mity Vac Bleeder.
Very easy job, especially on a non ABS bike.
Basically, you hook up the Mity Vac to the Calipers at the Bleed Screw. The Mity Vac creates a vacuum. Remove the Lid from the Master Cylinder. Have a helper keep filling the Master Cylinder with fresh fluid while you suck the old fluid from the Calipers with the Mity Vac. DO NOT let the Master Cylinder run dry or you'll introduce air into the system. If it happens, it's not the end of the world, but just makes the job harder than it needs to be.
When you see fresh fluid coming from the Calipers, you're done. Fill the Master Cylinder to the "Full" level and button everything back up.
Old 12-20-2011, 07:40 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Did mine the old shcool way on my '06.
Old 12-20-2011, 08:28 PM
drspencer's Avatar
drspencer
I have both the Mity-Vac & Service Manual.
If I had a long enough hose going from the Mity-Vac to the caliper, could it be a one man job?
Will there be a definite difference in color between the old & new brake fluid?
Thanks
Old 12-20-2011, 08:34 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
the older fluid is usually more "golden" in color.
the dirtiest part of the fluid is in the line near the caliper.
mike
Old 12-20-2011, 08:41 PM
artz's Avatar
artz
artz is offline
You could cheat and use a turkey baster. You would prob only get 60 percent of the old fluid, but....its better than nothing.
Old 12-20-2011, 09:22 PM
thenewrage's Avatar
thenewrage
thenewrage is offline
Where can you buy the mity vacs?
Old 12-20-2011, 09:25 PM
Lakerat's Avatar
Lakerat
Lakerat is offline
Anyone try this with just SpeedBleeders instead of the Mity Vac?
Old 12-20-2011, 09:30 PM
brgtr3's Avatar
brgtr3
brgtr3 is offline
Start at www.mityvac.com. But which model is best for use with the Harley?
TIA
Old 12-20-2011, 10:01 PM
Chunker's Avatar
Chunker
Chunker is offline
Harbor Freight for one place
Quick Reply: How To Change Brake Fluid?
