Vibration due to new motor mounts
Took my 2002 Road King classic in for the 35K service. The dealer called to say I needed a new motor mount. Picked the bike up and road it home. It now vibrates very badly. The dealer said that the new motor mount is a lot stiffer than the old ones. I mean it vibrates so badly that noise is coming from the pipes shaking. Took it back to the dealer. They said everything was in the tolerances, but with a new motor mount it should vibrate a little. A little vibration would be ok. I have a lot of vibration, which is not ok. Any idea?
Take it back to the Dealership and tell the Service Manager to take it out for a ride and then let him tell you that it's normal. If he does then tell him his work is supposed to be under warranty, you're not satisfied and you want it redone. If he refuses then file a complaint with MOCO and take your bike to another Dealer. Mention to that Service Manager that your bike motor has developed a vibration and you'd like him to check it out. Don't mention that you just got a new motor mount. When he returns from the test ride see what he says about the vibration. If he tells you that it need a new motor mount ask him to write up a Work Order Quote and tell him you'll be back. Call MOCO and speak with Customer Service, explain the situation and what the first dealer told you and then what the second dealer told you and ask MOCO for advice on what to do.
Did they just replace the front mount? If so, you can try loosening the mounting bolts (just enough to free up the mount), start the engine and let it run for a minute or two, and then retighten the mount.
What this will do is allow the mount to "settle in" to a natural position and possibly eliminate any existing preload on the mount, which could transmit vibration.
EDIT: Or do something like JJHOG recommended LOL. I guess my advice was more for the DIY types. If you took the bike in for a basic service, I guess you don't fit into that category.
New OEM motor mounts translate more vibration, don't matter who installs them or what tricks you use. Scrap the OEm replacement mount and get a Glide-Pro or Sta-Bo urethane front motor mount, no better mounts out there, period. Ask StiggyNot sure how the primary will develop cracks since the entire driveline is firmly fastened together and it all moves together.
read this https://www.hdforums.com/forum/touri...vibration.html
Really, I forget, tell me again what the OP's vibrometer reading was that places it outside the normal range. Yeah, the thing about troubleshooting over the internet is too much is lost in translation, from perception to interpretation. You've obviously never had one of the urethane mounts, that I mentioned, in your hand, because they are definately not as stiff as OEM mounts. When you pick up a bunch of vibration after a front motor mount install, it's probably the mount. You are free to think what you want, I have used both types of mounts and the two I mentioned are far superior to OEM, just a fact, not debatable. 2black1s suggestion is the best technique for aligning the new mount, but it will only slightly reduce the vibes.
Not trying to scare anyone but the two times I have heard this occur the engines had scissored crankshafts, this is not even funny to consider but I thought it would be a idea to inspect, they can find it with crank end shaft runout. Two of my riding buds had this happen, one a 1999 88CI RK stepped up to 95CI, the other a 2009 96CI stock Ultra so it is not a year specific or a CI specific. The repair shop stated it had to do with high loads(both guys are my size, very large) and lugging, both had done long trips with loads of hills and causes for lugging.
