96" SE255 cams MPG?
Old 01-02-2012, 07:57 PM
Lawdawg's Avatar
Lawdawg
Lawdawg is offline
Default 96" SE255 cams MPG?
Just curious what kind of mpg you are getting while cruising at around 75-80. For me that's 3000 rpm in 6th gear.
Old 05-09-2016, 07:12 PM
rideamap's Avatar
rideamap
rideamap is offline
I was getting 34mpg when being easy on the throttle. This was with a poor tuner. I just got a dyno tune last weekend and will update once I can get enough riding in.
Old 05-09-2016, 08:52 PM
FX4's Avatar
FX4
FX4 is offline
Way back when I had this setup with a good tune, 39MPG, although it was real easy to get down to 32-35MPG being a little heavy handed.
Old 05-09-2016, 09:04 PM
todd-67's Avatar
todd-67
todd-67 is offline
Received 3,405 Likes on 1,593 Posts
That is just about the speed range where economy starts to drop off. I have gotten no worse fuel economy on the highway when cruising at 65 to 70 with cams. Hot ******* around and anything above 70 it starts to drop off.
Old 05-09-2016, 09:17 PM
Superlow-Ben's Avatar
Superlow-Ben
Superlow-Ben is offline
I'm getting about mid 30s at that speed range.
Old 05-09-2016, 09:49 PM
mgmmgm's Avatar
mgmmgm
mgmmgm is offline
At 75 to 80 mph i'd have to check my power vision next time, but i'd guess it's 40 mpg without headwinds blowing.
Old 05-09-2016, 10:18 PM
texaswiz's Avatar
texaswiz
texaswiz is offline
Anything over 75-80 mph and it starts dropping like a turd in a well.
33 mpg-35 mpg.
The faster the bugs accumulate on the windshield-the lower the mileage.
Old 05-09-2016, 11:01 PM
2AMGuy's Avatar
2AMGuy
2AMGuy is offline
Received 2,461 Likes on 1,591 Posts
I had my T/C 88 updated to a "95" (not sure what cams they installed) and I got 38-39 MPG's running 70MPH at about 3,000 RPM's.
Now I have a CVO 110" (tuned with true duals) I get 39-40 at the same speed and RPM's.
However,as an earlier posted stated, when you start going 75-80+ the MPG's drop like a brick.
I thing the worst MPG's that I ever got was 32-33 running at 3,500 RPM's.
D W K
07-20-2014 08:21 PM
desertwolf
02-07-2012 07:12 AM
badjustbad
08-05-2009 01:13 PM
Duke of HD
07-15-2009 03:28 PM
turbo54
10-23-2006 01:16 PM
Quick Reply: 96" SE255 cams MPG?
