Electra Classic No Horn
I just bought a 2001 Electra Glide Classic yesterday, 11k miles. I have not bought a manual yet. Trying to get a answer ASAP I double posted, sorry but I want to ride!
My horn does not work. I did the search first and came up with nothing.
I did run power to the horn and it checks out.
I checked the switch and power is going to the switch, and the switch is working properly.
I checked the connection plug at the horn and it is fine
My problem is the wiring between the switch and the horn. When the switch is pressed there is no power to the horn.
The PO told me that the horn only worked sometimes and a buddy of mine with a 01 Road Glide or whatever, told me his horn sometimes does not work.
Any ideas an where to look first? Is there a fuse from the switch to the horn that I am missing? Or maybe a connector?
This is my first dresser although not my first HD. Rider for about 40 years, from PanHead to Evo. So go ahead and give me the low down.
Thank you,
Thank you,
[QUOTE=89 FXRS;9255454]
So you have power to the horn? Switch is OK, how did you check that? And how did you check the connection at the horn? Your trouble shooting seems to contradict your conclusions.
Have you placed a meter across the horn terminals and pressed the horn switch to see if voltage is present? If you voltage there, then your horn is broke. Go to the autoparts place and get a high or low tone horn and install it. It will hang fine under the cowbell cover.
If you have no voltage, check your fuse. If your fuse is OK, then check the wiring back up to the switch. Step at a time.
I'd lift the tank and follow the run. It's either in the bars or under the tank. I'd hope for under the tank.
Thanks but I was hoping for some one that had the problem at one time. Before I tear the whole thing apart.
I am guessing that it is common, somewhat?
My question is where is the wire run, can I reach it with just pulling the tank?
And are there any connections or anything alse in the wire run from the switch to the horn?
You could well benefit from revising the circuit.
use a relay to draw horn power from the battery, use the stock wiring ( once you get it sorted out) to open the relay.
this is like the horn circuit in the car and much more reliable, less sensitive to switch corrosion, ground contacts or temperature
Mike
Mike
