oil consumption and blow by
I was pulling the air filter and plugs today and noticed some oil on the bike.
Looks like quite q bit of blow by for one day of riding right? What is the reason I'm seeing so much oil around that plug? I've suspected that the front cylinder is burning some oil for a time now, would that be why I have oil at the plug or are the two unrelated?
I haven't seen oil weep past the plugs' compression sealing ring, even if you had major oil ingress from valve seals/guides. Check the plug itself real close, and I hate to suggest the worst but look for a crack at the plug hole. Got a pic of the plug itself? If that oil is coming out of the chamber, it's time to rebuild the heads.
yes the plug oil is a mystery.
oil in the air cleaner can have a number of causes, and can be influenced by cam choice and pipe specs, too much accel pump, jetting etc. if the fluid smells like gas that would indicate that some air containing fuel is reverting out the intake.
if pure oil, then it could be worn breather umbrella valves in the heads, overfull oil tank or a result of sustained high rpm operation- in most cases it's only an annoyance.
i have a Pal who has a maxi pad stuck inside the bottom of his air cleaner cover and changes that every 28 days...
if you are consuming oil- like a pint every 500 miles, it needs looking into
mike
mike
mike
mike
Looks like loose plug or bad seal ring, could try a new plug and torque it to specs. Your plug tip looks great, no indication of oil burning.
Oil in breather is usually normal but shouldnt be excessive. You could try a backing plate that vents directly back into the venturi ,i have them on my bikes and no oil shows up in air cleaner.
you can also open up the breather oil returns in the head, i cant seem to attach the pdf procedure but would email it toyou if you send me an address.
Thanks
