can't help you on the T-Mans, but here's another woods 555 dyno. You can see the mods in my sig. As Aviscomi said, I believe my tuner did a great job too, but he didn't start my run till 2800 on the printout. I would like to have seen it before
Gary, was that Dyno run using your existing exhaust?
I am looking at installing tman 555 torqster cams in my 2011 limited 103". I have installed the screamin eagle race tuner,Hi flow air filter and V&H power duals with Supertrapp slip ons. The local H-D dealer is doing the install and the dyno work. Anyone have an idea of what to expect for power and torq with this set-up? The dealer says i could get 95h.p. and 105 ft pnds.
My numbers are 87.99h.p. and 101.17 ft. pnds. of torque 4th gear dyno run.
I wasn't really happy with the tune so, I had my mechanic work on tunning it some more. 92.71 h.p. 102.08 torque in 4th gear. 5th gear pull showed 95. 14 h.p. and 109.98 torque.
being your bike is a 6sp you should have had him do a 6 gear run just for bragging rights. Looks like you found a good combo for sure. that cam is on my short list.
