i want to put one of the harley road winder wheels on the front of my 07 RG i know i have to change the bearings but i have upgraded to the newer brembo calipers and rotors does anyone know if the rotors will bolt on these wheels
i see the part # is for the different rotors but do know if my newer bembro rotors will work i was hoping they listed the other ones because they look better
Are you looking at the 16" or 18"? The 18" Roadwinder front wheel takes a floating rotor that as no center. The 16" takes any rotor with a center mounting flange.
The calipers will work. Try ebay I've seen some on there. Also if you can get the part# the vrod or '08 flhrse rotors are cheaper than the polished ones. Try Surdykes or lshd.com.
