New for Road King: Independent control of passing lights
Old 08-18-2013, 03:12 PM
MikeBel's Avatar
MikeBel
MikeBel is offline
Received 1,494 Likes on 637 Posts
Originally Posted by MikeBel
Help Please. I bought the HD kit and it's terrible. Going to return.
I've seen the wiring diagram we have on the forum. My question is, since I have a RKC with no fender light, can I simply use the fender light's orange/white power wire and splice it into the yellow power wire coming out of the headlight plug? This sounds like it'll work but I'm no electrician.
Thanks for the help!
OK, patience is not my strong suite sometimes. Sorry but I got irritated and confused on the crappy HD instructions. I did end up using the un-used orange/white power wire for the fender light (un-used on the RKC). I clipped the connector off of the o/w power wire. Then clipped off the yellow power wire about 3 inches down from the pin in the white connector that is attached to the passing lamps switch. I soldered the o/w to the yellow wire (with the pin connector attached) to supply constant power. I capped off the cut yellow power wire and taped everything back up. Works great and passing lamp switch still controls the on/off. Very easy to do once I figured out what to do.
  #72
Old 04-23-2015, 07:03 PM
LRIII's Avatar
LRIII
LRIII is offline
Stage I
Default aux installed backwards
I believe mine is installed backwards also, seeing as though i recently had some work done. Before my passing lights would switch on and off with switch. Now they wont turn on at all. Stuck on which wires or plugs ar backwards?? Anyone?
madwrencher
07-01-2019 08:53 PM
MMCSKPD
Milwaukee Eight (M8)
11-09-2016 08:25 AM
DellaPia
05-30-2011 07:15 AM
woredown
11-28-2009 10:09 AM
Jetstream
03-20-2007 11:36 PM
Quick Reply: New for Road King: Independent control of passing lights
