Where did you mount your Scorpio Alarm?
Sure they do. I just bought one for my '00 RKC 2 weeks ago on e-bay. Look for 68200-00C security system and 68314-01 Installation wiring kit. Going to cost you over $200.00 in parts but fits like a glove.
Questions: So, this is an ignition disable and not a relay interruptor (in other words can't be push started)? did you get 2 FOBs with the unit? Is this the unit that you can create some kind of code to disarm the system if you lose the FOB? Lastly, do you have the Smart Siren II?
Thanks again!
Had trouble finding one for my 98, eBay to the rescue! Got a NOS module and install kit for $100 from an HD dealer. Most won't have it in stock, they quit making the older ones I believe (dealer told me they couldn't get me one).
Kills the power from the start/run switch, so yes, it's dead, no push starting. Came with one fob, but I'm buying the Smart siren II and a pager, so I'll have that and then the original as a backup. You can program a disable code through the turn signals as well.
The kits are nicely designed, pretty easy to install if you're confident enough to plug/unplug some harness ends and remove your battery and gas tank (newer ones may not require that)
Sure thing! Not sure if it's exactly the same hookup, I think it may have been 97-99 or 01 FLH and 97-03 Dyna or something like that paperwork is in my garage, not where I'm at.
I pulled my EFI off, and one thing I noted was that the circuit I used to power the coil routed through the TSSM (from the the run switch). This means, even with points and a carb, I have all the same functionality as the original design. I mentioned elsewhere, but I plan to wire in a switch to silence the SSII, I mainly just want it for the pager functionality, not the 'being a noisy PITA' functionality.
jacknthebox
03-10-2010 07:19 PM
