Fairing Cap Removal
Fairing Cap Removal
I would like to adjust the handlebars and need to remove the fairing cap. I know that there are two screws, one on each side.
Do I need to take the ignition switch off? I removed the two screws but it seemed to hang at the switch. I do have a service manual but it is unclear to me about the removal.
This is on a 2011 FLHTK. Thanks
yes you will have to take the ignition off. found this video on youtube. hope that helps
http://www.youtube.com/watch?v=7-QBH1SFyzo
just the 2 close bolts
loosen, adjust, tighten
put a towel of blanket on the tank for preotection
if you go low, make sure that the controls cannot be pushed into the tank- the mounts are on rubber bushings and the bars will move when pushed, like moving the bike around the garage
mike
mike
Carl
