How long does it take to change out OEM Forks with Chrome ones
Get your parts together and set the better part of a Saturday aside to get started and finish. It's not difficult...but it sure is messy! Be careful with the allen bolts at the bottom of the fork tubes...they can be a bitch! Replace the tube seals with fresh ones...you need something to hold the fork tube stationary when you're removing the cap. You can use the triple trees to hold the tubes if you know what you're doing, but that can be mighty dangerous when that spring pops loose (don't ask me how I know that)! I use a tube holder made by Jim's Tools bolted to my lift...works very well for me! You need something to measure fluid when you go to put everything back together. Did I say that this is a messy-assed job?
Good luck!
Steve
Good luck!
Steve
Received 70,394 Likes
You can do the chrome exchange w/ outfits like ***** Shiney. (1st class)
I bought Steve's (SCJE8 the post above me's cans and lowers) and sent them to exchange to save some down-time.
While you're in there, get rid of them springs and get something like the Progressive monotubes.
You'll thank yourself the first time you go for a ride w/them. Trust me.
You'll have as good or better quality chrome and it will be made in America,
will be cheaper and not out-sourced to communist countries that rely on prison or dissident labor does like China.
Make sure you have an impact for the allen at the bottom of the forks. Make a fork seal tool out of PVC. Make sure you have a seal kit. An extra set of hands really helps. The motion pro fork oil level tool is helpful. You add oil then set the oil height. Service manual is a must. I think it took me about 3 hours the first time because I was being really careful and referring to the manual often. I did a set with a buddy on his bike and we finished in about 1.5 hours. Its not a hard job.
Doesnt seem too bad.......I am waiting on some cash to do the progressive monotubes and chrome lowers my self.....here are some threads that will help you if you decided too tackle it your self.
later
John
https://www.hdforums.com/forum/tri-g...-write-up.html
https://www.hdforums.com/forum/touri...p-updated.html
later
John
+1 on the monotubes. Best mod I've done to my bike (2011 Ultra Classic)
I just completed the job within the past couple of days.There were no surprises. Work one side at a time. Lots of folks say you need the impact for the 6mm plug in the bottom of each fork but I had no problem getting it out even off the bike. But when I do it again I'll loosen those plugs before removing the forks. I also had to buy a 1 3/8 wrench at TSC (about $13) for the cap bolts.
