Heat Demons
k thanks...
gonna be some boots to asses come tue morning when the stealer opens!
that douche bag even came up with different part numbers, for the left and right side kits.
I thought that only one kit was needed, but I didn't want to call the guy a liar.
thks for the help.
thks for the help.
Just installed Heat Demons on my 2012 Road King yesturday and wanted to pass on some tips . there is enough play in the T.B.W. cable in the headlight so it makes it easy to pull the twist grip assembly out of the bar.There is a orange and white wire off the headlight to use for power and a black wire for ground.solder all wire connections its worth the extra time,took about 3.5 hours,just take your time.better than letting the Dealer do it
