Khrome Werks sweeper 2+2
Anyone have experience with these new bars. Their website indicates that you only need a longer clutch cable. Just wondering about the brake line and if I will also need to extend the control wires. Not planning on internal wiring. I am going to replace the TBW to get rid of the green connector.
Thanks
Thanks
If they are only 2 inches taller i think you can get away with the stock brake line, throttle, and wires (shouldnt have a problem because those bars dont have internal wiring). Some bars are a little different but a lot of guys are getting away with stock cables on 10" apes (4" taller than stock). Sometimes if its close you just have to spend some time re-routing and double checking that they clear when you turn the bars.
Yea they are 2" higher and 2" more pull back. I know guys are getting by with the regular +2's, just wondering about the extra 2" taller. Can't remember how much play there is in the upper brake line. Want to have all the stuff on hand, so I can do the swap in a day. I agree that there is probably enough inside the faring for moving the wires around.
Thanks for the reply.
I have them on mine. Standard cables but the clutch cable is routed to where it would cause the wind deflector (that plastic $30 part) that attaches to the top of the crash bar to come off. I just removed that part for now
Sorry....i was thinking I was on the road glide forum....if you have a batwing my info is useless
Thanks to all. I intend to use a +4 Clutch cable and the Longer TBW without the green connector. Was mainly worried about the upper brake line, I have ABS. Sounds like I am good. Hope they do the trick because i need about 2" higher and farther back. It is the 300517 bar from khrome werks. For the question about notched or not, I believe they have both available, check out the new products section of the khrome werks website.
