How much air pressure in rear shocks
Old 03-16-2013, 11:59 PM
Denis1227's Avatar
Denis1227
Denis1227 is offline
Not trying to thread hijack, But I am have a 97 Electra Glide. Just put new shocks on the back. Have 30Lbs. in them. Just noticed today with the tour pack on and my wife, she is 140ish. I hit a bump and it bottoms out real bad. How much can I saftly put in to stoip this.
Old 03-17-2013, 01:55 AM
ButterBean12's Avatar
ButterBean12
ButterBean12 is offline
I'm pushin about 250...ok maybe 265 and on myRoad King I'm running 25lbs. solo in the rear The wife comes in about 145 and I run about 30 in the rear. I did replace the shocks with the newer ones so I can run more air in them. I usually run about 5lbs in the front.My roads are pretty rough and we don't bottom out on them but I wish I could go a little lighter on good smooth roads.
Old 03-17-2013, 12:11 PM
PhoneGuy-MI's Avatar
PhoneGuy-MI
PhoneGuy-MI is offline
I run 35#'s all for both 1 and 2 up. Every once in a while we bottom out on 2 up and I think I need to increase to 40# but never have because we have only bottom'd out like 2 or 3 times.
Old 03-17-2013, 12:23 PM
BeeRAD56's Avatar
BeeRAD56
BeeRAD56 is offline
I'm on a 2010 Street Glide and at 215 lbs, solo I like 30 psi, 2 up and gear I run 50.
Old 03-17-2013, 05:28 PM
BIGVTWIN's Avatar
BIGVTWIN
BIGVTWIN is offline
Wow I have a 09 and I weigh 235 and at 30lbs it almost throws me over the bars while breaking my back!
Old 03-17-2013, 06:25 PM
joe buck's Avatar
joe buck
joe buck is offline
I have a 2012 ultra glide and the air shocks suck no-matter what psi i tried 1 up or 2 up they rode like **** and would bottom out so dealer credited me 180.00 towards cvo shocks there so much better in every way
Old 03-17-2013, 06:50 PM
M1kefries's Avatar
M1kefries
M1kefries is offline
2nd Gear
At 256lbs I normally run 20lbs in the rears. Like others I keep the pump in the saddle bag and adjust frequently, but 20 is the average.
Old 03-17-2013, 08:53 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
Originally Posted by DK Custom
What has been most comfortable for us has never even been close the the manual recommendations.
When checking different PSI even 2-3 lbs can make a significant difference in the ride.
The other, counter-intuitive, factor is that more PSI can produce a softer (cushier) ride than less PSI.
ie. at 16 psi we are not bottoming out, but when we bump it up to 19 psi it is actually a softer ride than at 16.
I found that to be true also. Ive got mine at around #25 solo....I have a 1" lowering kit on the back and its needed a heavier weight to minimize a kidney punch ride.
Old 07-19-2013, 01:05 PM
Richie South's Avatar
Richie South
Richie South is offline
Stage I
Default air pressure in shocks
I had the same question and to all those who gave their answers,..thank you. to all those who said to "check your manual" I think most people would if they had a manual to check. sometimes the obvious isn't so obvious!
Old 07-19-2013, 01:15 PM
htc's Avatar
htc
htc is offline
I have 2010 Road King Classic and I second that. Straight from manual and that "two up and gear" just worked perfectly over 2500 miles in Norway.
Quick Reply: How much air pressure in rear shocks
