Factory hookup for battery tender?
Old 02-29-2012, 05:49 AM
widebody83's Avatar
widebody83
widebody83 is offline
Default Factory hookup for battery tender?
hello, I read on here where most bikes came with the wire already ran for the battery tender to connect to, but then i also read that it was up to the dealer to install. I have an 09 SG and my new battery and tender should be arriving today and was trying to see if i already had the hook up or not. someone said its by the transmission, I've looked down behind the transmission on both sides. no luck...
thanks in advance
Old 02-29-2012, 06:00 AM
ezriderpgh's Avatar
ezriderpgh
ezriderpgh is offline
Some dealers have them installed, some don't. If you bought it new your sales slip will show it. Otherwise, it takes 5 minutes to put it on.
Old 02-29-2012, 06:02 AM
OzarkHarleyguy's Avatar
OzarkHarleyguy
OzarkHarleyguy is offline
It is a dealer install. As was already said its easy but your dealer might give it to you or install for you.
shortride's Avatar
shortride
shortride is offline
My Battery Tender lead comes out above the starter and behind the heat sheilds.
Old 02-29-2012, 06:05 AM
LarryLives's Avatar
LarryLives
LarryLives is offline
I have also noticed it the bike was orig from a warmer climate they did NOT come with them...
Old 02-29-2012, 06:12 AM
Nut08Ultra's Avatar
Nut08Ultra
Nut08Ultra is offline
thanks in advance
For some reason I want to say that when I purchased my battery tenders they came with the bike hook-up as well as the hook-up that pinches, like a car cable, for a non permanent application. If it comes with one, just hook that one up yourself. It will take you longer to get to the battery then it will take to install on the battery.
Old 02-29-2012, 06:20 AM
Challenger's Avatar
Challenger
Challenger is offline
My dealer puts them on all new bikes. Mine comes out down by oil cap.
Old 02-29-2012, 06:30 AM
mkekid's Avatar
mkekid
mkekid is offline
When bought new in 08',mine came dealer installed. (Lower left on picture)
Old 02-29-2012, 06:39 AM
jeffreydsilver's Avatar
jeffreydsilver
jeffreydsilver is offline
Default Easy To Spot
When you uncover the battery to replace it, look and see if the "extra" tender wires are already attached, and then follow them out to the pigtail. If not, attach them once you drop in the new battery.
Old 02-29-2012, 06:41 AM
tcarille's Avatar
tcarille
tcarille is offline
Not all the bikes come with it.Some dealers put it on some don't.
Quick Reply: Factory hookup for battery tender?
