Changing passing lamps on SG
Old 03-01-2012, 04:59 PM
Rosanna's Avatar
Rosanna
Rosanna is offline
Stage IV
Default Changing passing lamps on SG
Purchased my '08 with aftermarket passing (fog) lamps already installed. I have decided to go with clear lamps instead of the present amber. Ordered HD lamps that match the headlamp and came with the quick connect wires. Previous lamps wired in and don't connect up with HD wiring. I've been told I need to buy a whole new assembly for the HD lamps to work with. Is there any other way around this?
Old 03-01-2012, 05:36 PM
Loc_Tite's Avatar
Loc_Tite
Loc_Tite is offline
Maybe I'm missing something, but can't you just pull the whole aftermarket assembly out of the equation and install the HD lamps? The connectors to plug the HD lamps into ought to be in the headlamp, unless the previous owner cut off the connectors and spliced the wires in which case you could also splice in the new lights. Or you could order the harness connectors from HD and re-pin the wires that are in the bike headlamp and install the harness connectors, then connect to the new lights.
Am I close?
Old 03-01-2012, 05:43 PM
Gliden's Avatar
Gliden
Gliden is offline
I used the spot switch that came with the kit but bypassed the whole surgery of the switch harness. I took a aux feed that goes on and off with ignition that was under the seat.....snaked a plastic snake right up the the middle under tank and into the lower fairing area.
It's already fused.
If the ignition is on, I can flip the spot switch on and the lights stay on and have nothing to do with high beams or anything. Completely independent.
Ultra 99
Electrical/Lighting/Alarm
02-14-2019 12:37 PM
deelip
11-08-2014 05:35 AM
rwb1
02-02-2014 04:29 PM
masterblaster
01-05-2008 07:49 PM
fryeca
08-21-2007 03:13 PM
Quick Reply: Changing passing lamps on SG
